Guest extreme_colors Posted May 4, 2011 Report Share Posted May 4, 2011 Got a call for an 06 charger for window tint. Have been tinting since Feb and have mainly tinted MINI's and BMW's. Haven't attempted any Dodge's yet. Any advice? We are using 3M FX-PM film. Thanks Link to comment Share on other sites More sharing options...
hungry&fat Posted May 4, 2011 Report Share Posted May 4, 2011 Cake... Just remember after you trim the bottom on the rear doors to slide it down some. Otherwise you may have a light gap on that curve. Link to comment Share on other sites More sharing options...
shwusyrtnts Posted May 4, 2011 Report Share Posted May 4, 2011 I pull the gaskets on these cars for ease of roll down install. It is easy to do just remove the screw from where the door handle on the inside is. The the top of the door panel is loose enough to just pull the bottom gasket out. On the back window I use a little masking tape on the headliner since it hangs over the top of the glass a bit. Good luck once you have done 2-3 these are easy as pie. Link to comment Share on other sites More sharing options...
Guest extreme_colors Posted May 4, 2011 Report Share Posted May 4, 2011 I haven't attempted to pull any gaskets as of yet. What all is required to pull it? Link to comment Share on other sites More sharing options...
coast2coasttinting Posted May 4, 2011 Report Share Posted May 4, 2011 pull out the screw right behind the inside handle, the top unclips and you can remove the lower gasket Link to comment Share on other sites More sharing options...
