Cutting windowfilm
I think you have to use a 45 degree blade. Depending on what kind of plotter you use. Adjust your pinch rollers and the pressure of your blade so it doesn't go through the liner and cut away dude. :rollin
Guest mushroomhead
make sure to cut little test patterns 1st if the peel good your good to go.also if you have skipped spots check your teflon slide in bad spot will cut through or skip
Guest solarguy
Your plotter needs to be set between 30 -65 grams of force. Use the test patterns to check the cut. If it peels your ready to rock and roll, if it doesn't increase the force. Oh by the way start your test cuts at 30 grams of force. Graphtec is a good plotter for vinyl, I have never tried to use one on tint before. If you can find a DGI plotter you can use it for both vinyl and tint. As for the blade angle I use the 30 degree blade (same a vinyl). It must be dead sharp. Don't try to use one you have previously used on vinyl, I have two sets one for tint and one for vinyl. I have tried the 45 degree blade I haven't been able to get it to cut clean. Hope this helps. :lol6
    2. 1
    3. 7
    5. 7
    6. 1
    7. 7
    8. 7
    9. 0
    10. 7
