Guest mitsu12 Posted May 7, 2004 Report Share Posted May 7, 2004 I first time here, don't know where to ask for help. I have 98 mitsu mirage trying to change water pump. quest is which way does the crank pulley bolt turns to loosen it and how to do so with out air gun? please help. thank you Link to comment Share on other sites More sharing options...
Guest Eclipse Posted May 7, 2004 Report Share Posted May 7, 2004 Link to comment Share on other sites More sharing options...
Guest Blade Posted May 8, 2004 Report Share Posted May 8, 2004 You need to go to waterpumpdude.com Oh wait....better yet, ask OT! Link to comment Share on other sites More sharing options...
Mdog Posted May 8, 2004 Report Share Posted May 8, 2004 sorry playa, this here is a window tinting forum. these forums are made to disguss window tinting tips and techniques for sepcific model cars. it would be a miracle if you got that question answered here Link to comment Share on other sites More sharing options...
Guest thetintshop Posted May 8, 2004 Report Share Posted May 8, 2004 first thing you do is, grab a whatchamacallit, if you don't have an airgun. slip it over the doodad, and use a thngamajiggy to hold the round thing in place. turn counterclockwise till you hear a loud "snap". the pump should come right off. wipe the blood from your knuckles and install your new one. no problem. if the pulley is frozen, you can use a blow torch to cut the pumpoff. it won't hurt anything Link to comment Share on other sites More sharing options...
Guest tintgod Posted May 8, 2004 Report Share Posted May 8, 2004 first thing you do is, grab a whatchamacallit, if you don't have an airgun. slip it over the doodad, and use a thngamajiggy to hold the round thing in place. turn counterclockwise till you hear a loud "snap". the pump should come right off. wipe the blood from your knuckles and install your new one. no problem. if the pulley is frozen, you can use a blow torch to cut the pumpoff. it won't hurt anything GREAT ADVISE THERE !!!!...I was going to tell him the same thing... Link to comment Share on other sites More sharing options...
Guest Blade Posted May 8, 2004 Report Share Posted May 8, 2004 And don't forget to check the level of your turn signal fluid. Link to comment Share on other sites More sharing options...
Guest thetintshop Posted May 8, 2004 Report Share Posted May 8, 2004 And don't forget to check the level of your turn signal fluid. I was going to mention that, but that's so elementary, I assumed he had already done that. Link to comment Share on other sites More sharing options...
Guest Blade Posted May 8, 2004 Report Share Posted May 8, 2004 wipe the blood from your knuckles I use a red turbo squeegee in this type of situation. Link to comment Share on other sites More sharing options...
Guest nautiboi73 Posted May 9, 2004 Report Share Posted May 9, 2004 Link to comment Share on other sites More sharing options...
