Dust or specs
Guest sololalo
Guest sololalo
I was reading an article here on TD about reducing dust or specs and it came to my attention that its mentioned " not to wet the window, only the film"
but if I do that I have trouble placing the film correctly on the window due to the lack of what should I call it :lol slipperiness.
so my question what do you guys suggest?
Click here to view the article
Guest thatsnappyguy
u can spray a lil bit on the window, just stay a few inches away from the top egde, thats where alot of the dirt falls down when it gets wet.
Guest mikeMN
Just mist the window with your water solution no need to hose it down. Or have a separate spray bottle with a little more slip solution to mist the window before you apply as that may help also. Or just use more soap :lol
Guest scottydosnntkno
how are you avoiding spraying too much solution on the back glass when doing a reverse roll??? :lol
I assume hes talking FG with only wetting the film not the window
Guest rondy_
how are you avoiding spraying too much solution on the back glass when doing a reverse roll??? :dunno
I assumed that too just wanted some talk lol
    2. 6
    3. 3
    6. 3
    7. 6
    8. 3
    9. 6
    10. 4
