FS 2ga wire, amp, subs and a sub box
Guest Murph.
Guest Murph.
I have about 150 feet of 2 ga. This is generic wire. This is made here in Dallas by Storm products. It is comparable to any high end brand. Don't be fooled by Audio Pipe or Power Bass.
$2 a foot shipped.
Brand new Rockford Fosgate Punch P8002. I got this amp for a friends car but it was too big for the amp rack.
Retail $599 asking $350 shipped
2-channel car amplifier
??? ?? 200 watts RMS x 2 at 4 ohms (400 watts RMS x 2 at 2 ohms)
??? ?? 800 watts RMS x 1 at 4 ohms (4-ohm stable in bridged mode)
??? ?? stereo or bridged mono output
??? ?? CEA-2006 compliant
??? ?? Tri-way capable (Tri-Way Crossover required)
??? ?? 4-gauge wiring kit and 150-amp fuse recommended ? wiring and hardware not included with amplifier
??? ?? MOSFET power supplies and output stages
??? ?? MEHSA transfers heat efficiently from the MOSFET devices to the heat sink for high performance
??? ?? TOPAZ eliminates ground loop noise
??? ?? trans-ANA circuitry keeps preamp signal clean
??? ?? NOMAD "intelligent" protection circuitry
??? ?? variable high-pass/low-pass crossover (40-400 Hz, 12 dB/octave)
??? ?? variable Punch Bass boost (0-18 dB at 45 Hz) with wired remote
??? ?? 17-5/8"W x 2-1/2"H x 11-5/16"D
Two used Power Acoustic 12" Fubr series subs and a Q logic 12" box.
Asking $50 each for the subs
Asking $50 for the box
I swapped out the box pictured here for a new one. It has never been used. Will go sealed or ported.
    2. 2
    4. 8
    5. 8
    6. 2
    7. 8
    8. 8
    9. 8
    10. 2
