Guest vital Posted November 22, 2005 Report Share Posted November 22, 2005 I read somewhere a while ago that you don't need glue or sanding on the matrix to get it to look right. it was something about dry dropping it. can someone explain how this is done please? thanks Link to comment Share on other sites More sharing options...
TintDude Posted November 22, 2005 Report Share Posted November 22, 2005 You tint as normal, then peel back the film to expose the dots only, then let the film dry, then carefully card the film up over the dots. It's tricky though and easy to screw up if you do it unevenly. Link to comment Share on other sites More sharing options...
TintWizard Posted November 22, 2005 Report Share Posted November 22, 2005 It's tricky though and easy to screw up if you do it unevenly. [*]340374 more succuss to applying glue or use vinyl Link to comment Share on other sites More sharing options...
tintnfool Posted November 22, 2005 Report Share Posted November 22, 2005 It's tricky though and easy to screw up if you do it unevenly. [*]340374 more succuss to applying glue or use vinyl [*]340390 Why fight something when there is a simple, professional solution. Link to comment Share on other sites More sharing options...
