Rear window rubber molding
Guest woodranch
  • Replies 31
Guest woodranch
Yes a little but gettingover it.There is a little rattling noise comming from the rear passenger window.I was just wondering if the removal of the rubber molding has anything to do with that.I don't know if the even remove the molding thats why I am asking.Whats normal percedure?
Guest woodranch
Obviously everybody does not do the same thing.Normaly do you remove the rubber molding on a porsche or do you just squeeze the tint so its even?There must be a answer to this.You guys do a number o porsches I presume.
Guest VOLTRON
more then likely its is a manufacturer problem then anything else. You are probably not familiar with it but alot of newer cars have to be felted because if not the hard rubber gaskets scratch the film after installed.
