TintWizard Posted March 1, 2006 Report Share Posted March 1, 2006 not trying to sound negative, but I did the old caprice the other day, (which is almost identical glass) and if you are not working with film everyday you will most likely never get this window in one piece because it takes a lot of time with the film to learn all the possibilities of shaping it. with this particular glass you may want to powder up the whole window then seperate with middle water line and shrink the top with dry method, then put water under the bottom half and wet shrink it with a white hard card. that's the first way I learned to do that glass. now I just do it all powder and then double check it with water before trying to install it. the wet check will help you . tint on. [*]377063 Or learn the soap method and have the best of both worlds with that window Link to comment Share on other sites More sharing options...
Guest zolar Posted March 2, 2006 Report Share Posted March 2, 2006 not trying to sound negative, but I did the old caprice the other day, (which is almost identical glass) and if you are not working with film everyday you will most likely never get this window in one piece because it takes a lot of time with the film to learn all the possibilities of shaping it. with this particular glass you may want to powder up the whole window then seperate with middle water line and shrink the top with dry method, then put water under the bottom half and wet shrink it with a white hard card. that's the first way I learned to do that glass. now I just do it all powder and then double check it with water before trying to install it. the wet check will help you . tint on. [*]377063 Or learn the soap method and have the best of both worlds with that window [*]377083 bingo wiz and no wet check required Link to comment Share on other sites More sharing options...
Guest stgllc82 Posted March 14, 2006 Report Share Posted March 14, 2006 ok I bought some 30 inch film and I think I gonna do the soap m*th. another thing I noticed on the film was I used the blue max 5 inch and when over it 2 times up down and side to side and I could still see water, so I cut an extra blue max down to 3 inches I dont want any bubbles later on. so ill see wat happenes I figure this is the last time im doing this window. Link to comment Share on other sites More sharing options...
Guest chino Posted March 14, 2006 Report Share Posted March 14, 2006 are you using a handle with the blue max??? if not then you might not be putting enough force on the glass to push the water out.... Link to comment Share on other sites More sharing options...
tintnfool Posted March 14, 2006 Report Share Posted March 14, 2006 2 pages on an 02 Imapala. Seriously, how much more can anyone say about this car. Lets start a topic on a 98 dodge neon and see how far that goes. Link to comment Share on other sites More sharing options...
Guest tintman330 Posted March 14, 2006 Report Share Posted March 14, 2006 I dont even heat shrink it. I just cut it one piece and apply it. the once inside I shrink the few fingers on the top inside. if any fingers appear on sides I cut along defogger lines slightly near fingers and and apply light heat on outside to lay it down Link to comment Share on other sites More sharing options...
