CRV quarter windows
Guest naughtydog
Guest naughtydog
I have a new CRV to tint tomorrow - I normally pull the panels and remove the quarter lights to tint these - takes time obviously...I want to tint them in place this time.
How do you find these windows to tint in place?? - a quick trim of the rubber will be required I imagine.
Any pointers anybody??
Naughty
I dont pell the CRV quarters
it can be done without trimming the rubber
your cut has to be on the money :lol
the rubber pulls up on the backside, if you must tuck a piece
if the 'ol memory serves :lol2
:spit:spit
Guest Al-tint
very true guest - I do charge good money for them - they are a pain esp the back glass!!
[*]375935
They are not hard to pull. Just grab the lower bolt spacer so it does not fall to the bottom.
The new back glass is better than past models that had the 10 lines going all around the edge. :spit
Guest naughtydog
I decided to remove the rear quarter windows - they only take 5 mins to do and the job is a lot cleaner.
pop off the door panel, 2 x 10mm's and 1 screw - easy.
Naughty
Guest tintgod
Naughty
[*]376732
most of those 1/4 window are so easy to take out..usually just two 10mm bolts and a screw holding them in...they just come out so much cleaner taking them out..specially the ones were the inside rubber is over lapping the window from the inside..
    2. 8
    3. 8
    4. 1
    5. 8
    6. 8
    7. 8
    8. 1
    9. 8
    10. 8
