Guest OnTheDarkside Posted July 30, 2008 Report Share Posted July 30, 2008 I'm curious..do you have to heat where your teeth are holding the tint? It must crease in that section to a certain degree Can you use heat to get out a little crease like that? Link to comment Share on other sites More sharing options...
kool kustumz Posted July 30, 2008 Report Share Posted July 30, 2008 yea! you can use heat to get almost any crease out. just dont use to much heat!! I use the back glass for my peel board or wipe down the side of the truck just behind the door and use that for the peel board. I never have any problems doing it that way. Link to comment Share on other sites More sharing options...
Guest sunbuster.ca Posted July 30, 2008 Report Share Posted July 30, 2008 I've used the frame window that im tinting to peel off of lots... make sure, frame and surrounding area are clean... Link to comment Share on other sites More sharing options...
spyghost Posted July 30, 2008 Report Share Posted July 30, 2008 why not a reverse roll? Link to comment Share on other sites More sharing options...
smookee408@yahoo.com Posted July 30, 2008 Report Share Posted July 30, 2008 I've got to learn how to do that. Sometimes in my shop the peeler is almost 15' away. When that happens I do a half peel then put the liner back and walk over to the car and re-peel. Link to comment Share on other sites More sharing options...
Guest Beeline Posted July 30, 2008 Report Share Posted July 30, 2008 you don't use a peel board and you don't cut on the car (besides the top edge)? Link to comment Share on other sites More sharing options...
Guest Sunlimited Posted July 30, 2008 Report Share Posted July 30, 2008 Peel board=glass I'm tinting Link to comment Share on other sites More sharing options...
tint_detective Posted July 30, 2008 Report Share Posted July 30, 2008 its all good tell you get a nose hair in your tint.. Or a booger.... Link to comment Share on other sites More sharing options...
Guest naughtydog Posted July 30, 2008 Report Share Posted July 30, 2008 Thanks for posting the pics. You have a good set of gnashers on you. Link to comment Share on other sites More sharing options...
Guest tdmillet Posted July 30, 2008 Report Share Posted July 30, 2008 you don't use a peel board and you don't cut on the car (besides the top edge)? correct I have a very nice cutting board. I cut all the pcs. then put them in the car were they go. and just roll my fat butt around and tint. Link to comment Share on other sites More sharing options...
