mates Posted February 3, 2010 Report Share Posted February 3, 2010 hey guys got an explorer booked for friday just need some ideas on what im up against , I pull panels or pull gaskets if they pull without panel removal (dont tuck much if I can help it) are the panels easy to remove ? any hidden screws or clips ? anything I need to be careful with such as clips that like to break ? hows the rear window I notice hinges slightly go into the clear of the glass could be a pain. let me know your expiriences !! cheers from down under Link to comment Share on other sites More sharing options...
TintWizard Posted February 3, 2010 Report Share Posted February 3, 2010 I own a 2004 explorer , but it came factory tinted so I only did the 2 front doors. just a couple of phillip screws , pull back , pull out the gasket Link to comment Share on other sites More sharing options...
Guest shadowline Posted February 3, 2010 Report Share Posted February 3, 2010 Did one a few months back, door cards take themselves off, very easy and simple nothing hidden. Top hinge, IIrc I taped the middle of the glass to the side of the body, then removed the bolts/nuts from the inside of the glass, swinge the hinge up out of the way, shrink, cut, install, then re fit the hinge, jobs a goodun!! Link to comment Share on other sites More sharing options...
