Mr. Micro Edge Posted June 25, 2013 Report Share Posted June 25, 2013 Piece of cake....for you panel pullers t20 screw behind the door latch handle and one in the door pull pocket. Panels pop right off and yep.... BAM...smack some tint and your done....quarters I just lightly trimmed the front edge of the seal and the brake light slides out once you remove two t15 screws from directly beneath the brake light from inside the truck area. Not a bad car altogether. Link to comment Share on other sites More sharing options...
bamh5 Posted June 25, 2013 Report Share Posted June 25, 2013 http://www.tintdude....13-chevy-cruze/ Link to comment Share on other sites More sharing options...
TintOhio Posted June 26, 2013 Report Share Posted June 26, 2013 I didn't click that link but you don't even have to pull the panels you can pull the seals out just by bending the top part of the panel back... for reinstall squirt the bottom side of the seal so as lube and slide it right on the metal Channel Link to comment Share on other sites More sharing options...
