Working with clear shield??
A good steamer is key for working with clear shield. Also having a second set of hands to help with the steaming and stretching is a big help. I found a solution similar to what you would use for tint works well and the heat from the steamer can help getting stubborn parts to stick better.
What about the flushing tack solution? The 30% isopropyl alcohol 70% water? I did a charger and found myself using that very little and when i did unless it was a flat surface it caused an issue.
