2016 cruze
doigc6988
did one of these yesterday. Normally I am a panel puller, but i found these to be a pain to take off. The clips do not separate from the sweep as easy as the charger or 300's do. As stated above, the sweeps are loose. If you are dead set on panel pulling, there are (5) 7mm screws for the back panels. One behind the door opening handle. one at the very bottom of the door panel. The other three are around the pull handle/window switch. The pull handle must be taken off to get to the two behind it. Not sure on number of screws for fronts, as I tucked those.
If you're stuck trimming it once it's inside, use a 30 degree graphic/wrapping knife to trim and a light touch, if its draping over the gasket a bit it just pokes through smoothly and you're basically not touching the glass at all.
Just did another one yesterday. Panels are annoying but they get better with each one. The clips at the top holding the gasket are more annoying than the Chrysler ones though for sure.
Shame they had to reinvent the panels, if they didn't, there'd be no annoyances really.
    2. 1
    3. 7
    5. 7
    6. 1
    7. 7
    8. 7
    9. 0
    10. 7
