DIY Cornelius Sprayer
Guest zolar
Guest zolar
I Have put together a LONG post of pics and links for building your own Connelius
for very little money or effort.
so here goes......
First
The tanks were popular for beverage dispensing before the Bag-in-box system
They are known as Cornelius, Firestone, or Spartanburg tanks
For this post will will be covering the Cornelius tanks
of those there are 2 main types of fittings
they are named for the type of fittings and posts
Ball lock [Pepsi]
Pin lock [Coke]
The ball lock were the most popular
..........and the type used for this project
For this project you will need a few parts
1] a tank
2] a liquid side, and gas side ball lock fitting
3] a hose and wand
4] some other fittings and/or clamps
5] an air compressor
The tanks can easily be found at:
soft drink bottling plants
home brewing suppliers
e-baaahhh
here are some links
e-baaahhh [$12-25]
http://www.weekendbrewer.com/homebrewkegging.htm [$26]
http://www.midwestsupplies.com [$27]
webtrolly.org [$35]
The fittings are color coded grey or white for the gas [pressure] side .........or intake
......And color coded black for the liquid side ...or output
They have 2 types of ends
Most have a threaded post, the hardware dude identified as a 3/8 machine thread
They are also available in a barbed end
here are some suppliers
http://www.rcbequip.com [$3.75]
http://webtrolley.org[5.95]
http://www.weekendbrewer.com [$5.05]
If you use the common threaded end you will need to terminate the hose ends with a swivel nut and stem
And secure the hose to the stem with a standard hose clamp
........or the Oetiker Stepless Ear Clamps like Cornelius used
Clamp Links
http://www.oetiker.com/
E-baaaahhh
So here is the hardware you need to get it going
Next you need an air compressor to pressurize the tank
.........if you use a conventional compressor at the shop
A coiled air hose with a standard 5/8 air fitting on one end
...and a swivel nut and stem on the other will work great
I don't have easy acess to a compressor yet
.........and I may want to charge a tank on a mobile installation
.........So a $5 12 volt dollar store air compressor is the ticket
it even has a gauge built in
just cut the tire end off ........and add a swivel nut and pressure side ball lock
.........on the Filmhandler site it says the tanks must be pressurized to 125psi
the rated pressure is only 130psi for the tank
I highly reccomend 60psi for a working pressure
You will need some hose to attach to the output side of the tank
The cheapest way out is clear poly hose found at the hardware store for 25?/ft
The hose found on the store bought Cornelius is by Freelin-wade called Flexcoil
if I am right in my sourcing
http://www.coastaltool.com
$17.50 with 5/8 air ends
I have found another source for transparent blue coiled hoses ... Plastair
I am working on a hose and wand with a 3/8 threaded end for the ball lock
...with the folks at Plastair
And I will add it to thetintdoctor.com as it becomes available :inot
The Spring Jet hose and wand are on my main tank
........and is available from Amazon
in 25' and 50' from $15.94
but the hose is thinner than the Commercial Cornelius sprayer hose
........and the wand leaves a bit to be desired
here are some hose links
http://www.spokanehose.com/
http://www.centralstateshose.com
The wand [or shut-off] can be obtained at many sources
Any wand from a pump-up sprayer will work
The Chapin Company makes sprayers for 44tools .........and damn fine ones
I have ordered their shut-off, and nozzle for my tanks for $3.10 each
here are some Chapin links
http://www.absolutehome.com
http://www.hechinger.com
You may want to add a gauge to your sprayer
They are available ready for the cornelius
from $16 and up
some links
http://www.williamsbrewing.com
.........or if you are creative the thread on most gauges is 1/4"
........and standard gauges start at $1.25 on e-baaaahhh
here are some more sources
Here is an exploded view and parts list for the tanks
The output side has a 7/8" nut securing the post and O ring
after removing... the tube pushes straight up to give you the ability to trim it and add a filter
And the wand can be removed from the shut-off on most any high quality sprayer assembly
to resemble the commercial Cornelius system's shut-off
......anyhoo, here is the end result :lol2
I have 4 Cornelius sprayers for less than the price of 1 replacement hose from the tool suppliers
Hope this helps my fellow tintdudes :inot
  • Replies 73
Guest Al-tint
Nice post Z.
I made two much the same. When you use it swing the hose over the tank so that the weight of the hose and water is not hanging down on the valve. I pressure mine at 30 to 40 pounds.
Inlet.
Outlet
Filter
Guest willie
awesome post Zo - I'll get you pics of mine soon -mine look more like Al with a fram filter on
and I have a vlave stem on my inlet
any suggestions for filters on that tube- Im gonna work on getting mine out
And not to be contrary but mine are old Dr Pepper tanks, ball lockes but some are different sizes
If anyone needs these let me know, I got a buddy that works for Dr Pepper :DD
Guest zolar
Nice post Z.
[*]389200
Al is that a Chapion shut-off for the sprayer :DD
good point about the weight of the hose and slip :DD
the ball locks will leak if they are pulled to one side
:dunno
Guest zolar
[*]389216
I have seen the small in line fuel filters
they will probably work
I would like to see the diffefence in a Dr pepper tank
the ball locks are different on each side of the tank anyhoo :DD
Guest willie
[*]389216
[*]389224
your right -the only difference are the ball locks -I couldnt get my coke fittings to fit and of course not the pepsi's
my tanks are from mid to late 80's -the later DrP and cokes may be the same :dunno your the expert not me :DD
and I could have been just that mechanically uninclined on the ball locks -I would bet this :DD
Guest willie
how did you get a hole in that stainless cap :DD
I broke the dril bit  :DD
I like the hose fitting on the tank on the left  :dunno
[*]389233
see I think this is where mine are different Zo
My cap screwed right off and I just use a tap set and threaded it - the valve stem just screwed in then
my outlet tube is molded into the tank and wont come out
I have some pepsis and cokes Im going to look at them
    2. 1
    3. 7
    5. 7
    6. 1
    7. 7
    8. 7
    9. 0
    10. 7
