02 xtype
pierce8468
If you leave the key on too long it screws the computer system up. The car wont start at all. It will sound like the battery is dead. what you need to do to fix it is this. turn the key to the on position and try to put the car in gear. It wont go in gear but you will see the light of the s button turn red. When that light goes on you then need to turn the key while it is still light to start the car. you then have to let the car run for 20 mins. Because it still will be messed up the car will not go into gear. after the car runs for 20 mins turn the key off and wait thirty seconds. then start the car again like usual and all should be fine. hard to beleive you have to go through all this but you will have to
Guest expertint
Thanks for the info Pie..I let Mike go..I think he got involved with some bad people from the Flaming Hotel..You should be glad you left..
    2. 8
    3. 8
    4. 1
    5. 8
    6. 8
    7. 8
    8. 1
    9. 8
    10. 8
