2004 Audi A3
Guest Rockabilly
Guest Rockabilly
For those that pull the door panels...
The old model A3 had a screw at the front and rear of the panel, undo the screws and the panel simply lifts up - there are hooks that hold it in place on the door.
The NEW A3 is different. Only one torx screw at the bottom of the panel, but this does not need to be removed. Just wind down the window, pull back at the top of the door trim and the plastic clips pull away from the door. You dont need to pull it very far, pop pop pop, just enough to remove the rubbers. And away you go.
