1985 starion
Guest gladihatersbro
Hey! I have a question and I am hoping you guys can answer it. I could be gettin this weeked a 1985 mitsubishi starion esi turbo. Comes with 170 hp stock and 220 ft torque. Now the guy wants 1200 or best offer.. he says there is nuttin wrong with it is a 5 spd new clutch new header new radiaiter new everything pretty much as far as engine. He says it has a small dent over the driver door but u can hardly see it but it needs a paint job. I have looked up this car and they say it is a really bang 4 your buck. It is actually a race car that in the future was made into the eclipses. hmmm anything else yall need to know jus type back....1985:
Starion LS
Starion LE
Starion ES
Starion ESI (1985?)
Conquest LE
Drivetrain Changes:
Water cooled turbine bearing housing (All)
Stronger Driveline (5 lug tire hubs on ESI )
Manual transmission change ?? model (10/85-05/87)
Manual transmission change ?? model (06/85-05/87)
Block change (09/85-end)
Chassis Changes:???
Available Colors:
Pearl Exterior w/ Blue?? Interior
Gold Exterior w/ ?????? Interior
White Exterior w/ Tan Interior (Conquest)
Burgundy Exterior w/ Burgundy Interior
Red and Black?? w/ Gray Interior
Available Options:
Auto Transmission (Starion LE, Conquest)
Air Conditioning (Starion LS, Conquest)
Technica Package (Conquest)
Digital Instrument Cluster
Electronic Voice Alert
Body Side Trim
ESI Package (actually a 1985.5 model)
170hp @ 5000rpm (SAE Net)
220ft/lbs @ 2500
7.5 PSI boost
Intercooler
Compression 7.0:1
Rear Wheel ABS (EIS only)
15"x6.5" 5-bolt Rims
P215/60HR-15 tires
Limited Slip Differential
Available w/Manual Transmission only
9.92" rotors (front), 9.65" (rear)
Steering Ratio: 14.3:1
Stabilizer Bars = .83"(front), .71"(Rear)
Technical Service Bulletins Issued:
TSB 18-52-86
TSB 21-10-90
TSB 21-18-90
I got this from a website this is all the specs
Yeah..theonly thing I need to know since this is a tinting forum is :
Does it need it's windows tinted :crazy
    2. 8
    4. 8
    5. 8
    6. 8
    7. 1
    8. 8
    9. 8
    10. 0
