Hey guys, Hope all is well by your side! Quick question: I went on site to remove a tint that were installed approx 2 years ago. External window film, don't know the brand of that film. Once I came on site and tried to remove the film with pure alcohol and cleaning blades, I struggled a LOT. It took hours for me to remove the adhesive. After the film has been removed, I spotted on the window some kind of weird marks that appeared as you can see on the attached pictures (only a few marks here and there on the glazing). I tried to remove those marks from the glazing without any success... Did someone experienced the same issue and has potential solution to remove those marks? Would it be the film responsible for such issue or, did I miss something during the removal process of the film ? Any piece of advice would be appreciated. Thanks in advance for your support!
