Vinyl
Guest Retro Tint
Guest Retro Tint
I have always treated vinyl much like film but have run into a problem with "Gregory" brand on two accounts. (1) if liner gets wet at all, it cannot be removed. (2) Looks milky on some dot matrix's. Never had this problem with Oracle. I know, buy Oracle, but Just wondering if anyone else has had similar problems with other brands. :krazy
Guest Retro Tint
I'm talkin saturated, with just a little water exposure. Talked to a rep here local and he said liner should have some sort of wax type coating to help repell water at least for a short period.
Guest Retro Tint
from my experience if you get the backing of vinyl wet u r done for :krazy
[*]338782
Sounds like I'm the last to know . What do you do to keep liner dry? There :beer is some obvious ways, but any good tricks?
Guest tint rookie
tryin to peal 1/2 spray set, do the other half. done for.
ill get in the back, lay it accross my lap, peel, spray, and franky that badboy up there. luckilly its vynil. your not looking through it and if there is an imperfection its gone once your slip is squeggied out.
Guest Retro Tint
[*]338793
I'm just talkin cuttin the pattern. Do you use a flat cuttin table ? Mine's vertical , so I have wet it.
    2. 2
    4. 8
    5. 8
    6. 2
    7. 8
    8. 8
    9. 8
    10. 2
