Cleaning rolldowns
Guest chip01
How do most people do it? Do you put the window down a little then scrape scub squeegee wipe edges and spray down. or do you leave the window up do the little at the bottam you cannot get to with the window down a little. Do you also wipe the top edge with the window wet or when you have squeeged it off.
What is the best squeege to use do many people us the 6" black squeege
with a handle, then go horizontal across the window to clean it or is it difficult to manouver
Thanks
Guest Sprinter
start with the window down and clean the rubbers and tape the felt up use a damp micro fiber towel for the cleaning.
wipe window top edge as it goes up now wipe the outside of the window off.
now on the inside after you've cut your film and are ready to install scrape the bottom and all the glass you can get to and then use a scrubbie pad over the same.
now lift your film if you use your window as the transfer board and roll the window down about 2 inches. finish scrapeing the rest of the glass and also hit it with your scrubbie pad and do hit the top edge with the scrubbie also now I use a micro fiber towel and wipe the top edge and down the sides and then squegge all the glass I use a yellow turbo squegee then all you have left to do is wet the inner sides and bottom and then install your film.
peel and wet your film and then install :lol6
