Cornelius users
Guest naughtydog
Guest naughtydog
Further to Zolar's posting of how to convert a cornelius tank as a pressure sprayer I have decided to make one.
For those that use them, what are the advanttages you feel you get from it, do you use it for flushing as well as soaking your film after liner removal, do you blast down felt areas with them?
Somebody mentioned that they have less contamination since they changes to one - enlighten me please...
Can I drill the top and use a normal rubber tyre valve of a car to pressurise it ? or does it have to be something more heavy duty?
Naughty
I only put about 30 lbs in mine. I like the fact that I don't have to pump the @#%$ handle :inot
Also put a 20 foot hose on the thing (you'll have to convert to meters :inot )
And put a metal valve (with the rubber seals) that tightens with a nut instead of a rubber one :lol2
Guest Al-tint
30 - 40 psi
50 ft coil hose
half full lasts all day
no pissy little hand held bottles
I think a cleaner install
never go back.
Guest tintgod
yes..yes...and yes
you get more flushing power out of them..as you flush the whole window down and sides..flushing dirt and airborn contamination out and down the glass
yes..a normal valve stem works just fine
Naughty
[*]402883
you will neve rgo back to another sprayer once you use one... :inot
Guest zolar
those tanks must be hard to rinse clean
I am a wimp when it comes to lifting things
no tanks here :lol2
[*]402890
lifting ???? :inot jiggra please :inot
I put 60-70 psi in mine
...but I like living on the edge :inot
I have 4 sprayers now
I will never go back
...and what is this contamination thing you people speak of :inot
:inot
Guest tintgod
:lol2
[*]402895
its all the stuff you have in your tint jobs :inot :inot
