bmw x5
Mr paladin
Didn't see much on here about this one anything to look out for?I have one on it's way in :thumb
panels come off easy, just remove the top part, 1-2 screws behind the door hande cover, one behind the "air bag" clip, another behind the handle to open the door.
back window may look hard to do but its day.
Guest Tint Technology
We do them nearly everyday,no problems, 1 hours work, don't bother panel removing, line your film on the outside bottom rubber, trim the sides, drop the glass and cut the top edge, neaten up your cuts on your board, clean, drop the glass 1", install, top edge first, microedge, card, close the window, hook the bottom edge under the rubber, squegee, job done. No damaged panels, broken clips, 10 minutes max for a roll down. :thumb Template the rear sides and quarters, back glass easy. Have fun and post some pictures :thumb:thumb:thumb
We do them nearly everyday,no problems, 1 hours work, don't bother panel removing, line your film on the outside bottom rubber, trim the sides, drop the glass and cut the top edge, neaten up your cuts on your board, clean, drop the glass 1", install, top edge first, microedge, card, close the window, hook the bottom edge under the rubber, squegee, job done. No damaged panels, broken clips, 10 minutes max for a roll down. :beer Template the rear sides and quarters, back glass easy. Have fun and post some pictures :beer:beer:lol2
it seems you allready started training for the next tintoff :thumb
If your a panel remover ( like what I am, but trying to master tint technology's method but not there yet)
Behind plastic clip with airbag motif and the chrome type strip ( which pops off easily ) there are 2 torx screws, remove these, pop the panel along the top edge and remove the weather strip alowing easy access to slip your film between door and glass.
takes 2 mins to remove trim and screws and weatherstrip if not able to tint with panel on.
I was advised when they came out at first NOT to flush the left hand rear quarter glass as all the electronics where located below this, as in the range rovers. If it gets too wet it fcuks up the sat nav and electronics.
Bob
    2. 1
    3. 7
    5. 7
    6. 1
    7. 7
    8. 7
    9. 0
    10. 7
