Celica Mk2 (96)
Guest walestint
Guest walestint
Celica mk2 rear glass (uk)
Had one today - film wouldnt lay that well for shrink
have done other celicas no problem, must be different years
any tips - its a bit like the mondeo back glass
:lol6
Guest smcmahon
need a pic? is it the model before the last one they brought out cause the last model of celica the back glass is flat and easy to shrink!!!
Guest ecocent1
this one wasnt flat!!
i was like an upside down boat
did no like de tint :lol (well mine neway)
I found the generation of celica is difficult. The easiest way i found to shrink it, is cut it as close to the actual size needed. Then use a dry shrink method so you havea large bubble at the top and one at the bottom. Slowly shrink across th edge of the bubble and continue to work back and forth until you have completely shrunk the bubble, and then do the other bubble the same way.
Guest iChoice-Tint
I di
I was like an upside down boat
did no like de tint :beer (well mine neway)
I did a 1990 model yesterday, failed 4 times and finally I figure out a way and it worked on my 5th attempt: anchor the bottom/side, not middle/side, I.e. to form a "U" pattern, not a "H' pattern, and dry shrink from bottom to top. It work pretty good for me.
    2. 1
    4. 2
    5. 1
    6. 8
    7. 8
    8. 2
    9. 8
