Need a tip...
Just did a shuttle bus today with flat, simple windows. However. No seals to trim and used a 5 way tool to get as close to edge as possible. Light gaps..... Not bad, but wondering if there is anyting I can use besides vinyl to cover it up. Is there a simple weather stripping that is subtle that I can wrap around the glass just to cover up these gaps? I hade to leave small ones in order to channel water. Any advice? thanks :beer
Guest haroldshouseoftint
:) how are those windows in there, hard plastic seals :beer if so, and if your confident enough to do it, lay a bead of black silicone around those frames. :beer
silicone is more messy.....if you can find a black latex it will be cleaner.
I did a 77 Ford Bronco and used silicone on the edges of it....what a mess. I used a lil chisler to drag it to a harder line edge...but that crap is a mess. With a latex you can use water to clean up....
:beer that's what I meant, sorry, your right silicone is messy.
I know what I meant in my own mind :)
    2. 1
    3. 4
    5. 6
    6. 4
    7. 0
    8. 4
    9. 4
    10. 6
