Cutting around matrix
Guest mattstronguk
Guest Litespeeds
That is a very good tip and deserves to be the TOTW. Usually cutting the bottom portion of the tint is difficult when working with a dark film and dark interior. What I do is use a white piece of paper and place it between the rear deck and glass so I can see the matrix before cutting. Of course some lighting will help too. Also if you turn off the shop light, you will be able to see what you are cutting more easily when you have light inside the car.
I am going to buy a roll of white pin stripe tape and try this out. Thanks for the tip! :beer:klingon
