Question - do you PRE-SQUEGEE?
Guest RCOOTE
push down with your hand before you use the bluemax and make sure it is wet enough.
This is what I do also, I usually smooth out the larger bubbles with the back of my hand
But after center anchor, I start towards the bottom with the side to side squeeging, especially if its old windows, and depending on the glazing, because I have found that pushing all the water out from the top down, can sometimes cause contamination to run out as it travels downward, especially if its rubber gaskets. :dumbass
Guest RCOOTE
I simply solved my problem with PRE-SQUEEGEE using the 10" 0r 14" black rubber unger handle, same one for cleaning, like DD.
I do have enough solution, Don't get me wrong, I'm not creasing everyday, it was just a spell there that I seemed to crease like 3 in one week. Since I switched it up, no more creasing....
Thanx for the input DUDES!!
