Wall mounting a Filmhandler
I had a friend weld two pieces of steel together the top is the same size as a aluminum ladder top...and the part that mounts to the wall is a little bigger....did the same mounter a two by four to the wall and the plate to that and use the screw up the middle to hold it to the steel bracket.....
I've had a wall mounted 72" unit for quite a few years now and it sags when utilising the poxy light weight wall mounted bracket supplied for the centre.
Buy an additional bracket and position the 2 of them a third of the way along the FM. That should make it more stable and better 90 degree accurate cutting.
Devil
    4. 2
    5. 2
    6. 2
    8. 0
    9. 6
    10. 4
