Film Has To Be Pre-Cut. How To Cover Gaps?
Have to install some tinted film on top of safety film which has been anchored with black Dow Corning 995.
Since we can't cut the new film on the glass the new film will be precut then installed. There will be gaps at the edges between where the new film ends and the 995 caulk begins that we will have to cover up. We can have more DC 995 caulked in to cover the gaps - but since it's just an appearance issue is there an easier, cheaper way to go like using black tape or similar to cover gaps like this?
Guest FilmBlazer
Just an FYI you will probably be voiding both warranties with that application. I would just use regular caulk, and I would pay someone else to do it lol :thumb
cut short and caulk with a pure silicon black so it looks the same and sticks. Siliconized Latex caulk will shrink away and peel after about a year as it won't bond to the the 995. Messy though and sticky as **** so use the tape trick on both sides of it.
Guest Bulldog
Dow states that 995 will bond to itself. Since this will only be cosmetic, roll with the 995. Other tapes, silicones will not match and in the end only cause probs>>>>>
    Tint My Ride
    rewiredtech.io
    3. 2
    6. 8
      Streaks after window tint
    7. 2
    8. 8
    9. 2
    10. 2
