Bmw E60 5 series
Guest shadowline
Guest shadowline
Got a 2004/5 E60 touring booked in, not worried about the rear end, just a bit nervous about the passenger doors, I normally pull panals so am hoping to pull theses if there not to bad. Are the "frames" at the top of the rear doors tight to cause a problem? Any tips would be great, cheers Guys
Guest tintdeck
no need to take the panels off prize the door panel away from the top on like spring clips with a hook tool you can pull the seal out got to be carefull not to bend it out of shape .
