2010 E coupe door panel removal
tintinater
Guest tint51
This is an extremely easy door panel....First, remove shiny end plate held with 3 torx (no pic, but obvious)
Second, carefully pop cover revealing 1 larger torx
Third, very carefully pop off metal trim piece, it's got some funky pops I've never seen
There are two more larger torx up in the openings under the handle
Then pop the door panel and lift up, popped off very easily, I was totally surprised (here I have it rested on a bucket, no reason to take it completely off)
The felt piece is a little tricky, but comes off easily as well, it's attached to the front so just leave it hanging and tint yer winder, then put it back together
Here's my disclaimer....I'm just a dumb old tinter, if you mess up someone's car using "my directions", then your an idiot :twocents
Is this the same wth the 2008 E350??
Guest bnsautomotive
anyone got any info on the rear drops? e350 coupe 2010
1. line up the bottom
2. cut the back
3. shift back roughly 1/8"
4. squeeqe to mount and cut front
5. lift bottom and tap widow down to cut the top
6. clean inside, sqeegee, and spray
7. peel clear liner leaving 2" on the bottom
8. spray and apply.
9. after tacked to the top roll the window up
10. tuck the bottom gasket if you must
11. peel the liner and spray then complete.
    2. 8
    3. 8
    4. 1
    5. 8
    6. 8
    7. 8
    8. 1
    9. 8
    10. 8
