dow 995
Guest teamfutaba
what tips are you useing ...I have a 3m gun but cant find the 3m tips...I can get the coxs tips....do the orange ones work well?
if your doing a big job, buy the electric cox gun. you will never squeez again. dunno if the tips are interchangable.
The yellow and the orange are similar. just the shape at the first inch or so at the base is different. Also some nozzles have a flat ring inside the bottom and some are"V" shaped. if the tip or nozzle fits in the collar it will work.
I cut the tip at an angle so the width of the opening is the desired width of the silicone bead. I have a video of it on www.filmfastener.com weather you use BondKap or not the silicone gun and tip process is still the same.
I hope this helps.
    3. 4
    4. 4
    5. 4
    6. 3
    8. 4
    9. 1
