mondeo mk2
Guest orion tint
Guest orion tint
hi peeps, I see this has been posted a few times but I can't seem to find the answer. What is the easiest way to tint the rear window in 1 piece I have tried moving the horizontal anchor up and down the window which does make a diffrence but still keep getting creases in the film. I also seem to get horizontal fingers as well as vertical , I have heat shrunk a few rear windows but I am self tought and my limited knowlidge of this has got me stumped. I know these are not the easiest of rear windows and any tips would be a great help, Thanks in advanced
Hey Orion,
If I had your experience I'd forget trying to do that back screen. In my opinion they are more tricky then VW beetles - not only is the shrink difficult to get right but cutting out the elements for the demister bars has to be done carefully as once fitted on the inside you can end up with light leaks if done incorrectly. There aren't any more tips you can have that are not on this site. I'm afraid it comes down to experience and having that feel for working with the film.
I guess your learning there is more to this then meets the eye - one thing I'd say is stick with it, if you can get this one on perfect you'll be able to do pretty much anything :dunno
Guest orion tint
that was my thought, work out the hardest one and everything else should work out fine, I will keep trying as I'm not a quitter maybe I just havn't found the method that suits me best. Thanks for your help though :dunno
    3. 8
    4. 8
    5. 2
    6. 8
    7. 8
    8. 8
    9. 2
    10. 8
