Peugeot 308
FEARON
Ok, did one of these today, took me 35min :boogie
joke
Right, Door panels easy removal, 2 small torx, One on the b piller side of the door pannel, cant miss it, sticks out with no cover on, one in the door pull where the electric window button is, this one is covered....
Undo the 2 torx, and pulll, gasset then just falls off... Easy fit ment.... Make sure the drop is heated fooking well, cos when the gasket is on there, its uber tight, and if its not dry, it will bring the film up when the drop goes up and down, so remember this when cutting that the film sits well below the gasket, so no edges skag.
Rear screen, easy, had alot of static on it, but easy, nice clean easy install car.....
