Ford Ranger 02 plate
Guest orion tint
Guest orion tint
How do you guys deal with the rear window in one of these, do you trim the rubber or remove the glass completely if you remove whats the easiest method of removal when working alone, Thanks in advance.
  • Replies 26
Guest thatsnappyguy
unless its a very old ranger without the black painted edge, and the window is just sealed in with the rubber....dont remove it. just cut it as tight as possibe. sometimes you may need to pass the blade across a lil rubber here and there...but that back glass and the new tundra, and the older f150 are just alike. take the extra cutting time and it will fit like a glover.
Guest shadowline
Cut it close on the outside when installed you can leave a tiny gap around but due to the bevel on the rubber surround you cant see a light gap from the inside, i dont bother to pull windows like this
a 2002 ranger in the uk must be different than the ones here.
i'm thinking the same thing snappy , any of you got a pic of this thing ?
In think the later ones are bonded...but not 100%
Guest filmslayer
is this what y'all are talking about ?
dosent that one have the opening section in the middle of the window....
...im sure this one in question is rubber fit
    2. 1
    4. 2
    5. 1
    6. 8
    7. 8
    8. 2
    9. 8
