hdrumm Posted December 12, 2010 Report Share Posted December 12, 2010 Any advice / tricks to making the removal of 3M dusted crystal easier? I've removed it before with great difficulty and would appreciate any advice to make the job easier. Link to comment Share on other sites More sharing options...
Guest Retnitorp Posted December 12, 2010 Report Share Posted December 12, 2010 Any advice / tricks to making the removal of 3M dusted crystal easier? I've removed it before with great difficulty and would appreciate any advice to make the job easier. Do you know how old it is ? What are the sizes ? Type of glass it is on ? Link to comment Share on other sites More sharing options...
hdrumm Posted December 12, 2010 Author Report Share Posted December 12, 2010 oh no!?!? Does the lack of responses mean that there is no easy method just alot of muscle and time? Link to comment Share on other sites More sharing options...
hdrumm Posted December 12, 2010 Author Report Share Posted December 12, 2010 Thanks for response. Single pane tempered glass. 1' X 5' panes. film has been there for 10 years. Link to comment Share on other sites More sharing options...
coast2coasttinting Posted December 12, 2010 Report Share Posted December 12, 2010 i like to use a steamer, but if that stuff is that old you better pack alot of elbow grease and alot of razor blades Link to comment Share on other sites More sharing options...
hdrumm Posted December 12, 2010 Author Report Share Posted December 12, 2010 nice pic. I don't have a steamer so it looks like elbow grease and time. Link to comment Share on other sites More sharing options...
Guest Retnitorp Posted December 12, 2010 Report Share Posted December 12, 2010 Thanks for response. Single pane tempered glass. 1' X 5' panes. film has been there for 10 years. First thing you need to do is check to see if the film is on the rough side of the glass "seeing how it is temperd" so you do not scratch the glass when removing the film. You will need to use a 4" scraper for this, start in the middle of the window and make a full 4" path, go slow and move the scraper back and forth as you go, wet the window and now just remove 2" at a time starting over and at the 4" path you have made, you will find that if you do this slow it will come off hard and take a lot more muscle, speed is the key that will make it more easy to remove, the faster you can go when scraping it off you will see that it will take not much muscle to do so, i like to hold the scraper with both hands one hand on the handle and useing two fingers on the end "side" above the blade to help keep the razer blade tight to the glass and help to guide the direction of the scraper as i make the 2" path when removing, and change your scraper blades as you go and keep it wet. Thats is one way to remove that film. Link to comment Share on other sites More sharing options...
TomTint Posted December 12, 2010 Report Share Posted December 12, 2010 Earlier this summer we has to remove DC from 14 windows that were 56 x 108. I had the same questions you do and you can probably usethe search tool and find the thread. We ended up spraying it with a strong ammonia/water mix and using black plastic trash bags to let it bake. After about 20 min per unit, the stuff almost fell off. Clean and almost no glue residue. Someone here gave me the tip. I think it may have been Mike MN. If I forgot to thank him...... Wow did it make my life easier. Thanks. Link to comment Share on other sites More sharing options...
WearTheFoxHat Posted December 13, 2010 Report Share Posted December 13, 2010 Link to thread Tom Spoke of.... http://www.tintdude.com/forum/index.php?sh...c=58281&hl= I kind of like reply 16 : Link to comment Share on other sites More sharing options...
Guest Retnitorp Posted December 13, 2010 Report Share Posted December 13, 2010 Earlier this summer we has to remove DC from 14 windows that were 56 x 108. I had the same questions you do and you can probably usethe search tool and find the thread. We ended up spraying it with a strong ammonia/water mix and using black plastic trash bags to let it bake. After about 20 min per unit, the stuff almost fell off. Clean and almost no glue residue. Someone here gave me the tip. I think it may have been Mike MN. If I forgot to thank him...... Wow did it make my life easier. Thanks. That way would be a Waste of time IMOP on a window that is only 12"x60"... Like i said i have a few ways to remove that film, I bet that ammonia smells real good..... Link to comment Share on other sites More sharing options...
