looking to bring in a high end film, ceramic or carbon...
NOW HIRING: Experienced Automotive Tint/Vinyl Wrap Installer
Tint World Louisville, KY Want to work in a state-of-the-art climate-controlled facility, for a company that will provide regular continuing training for a long-term career, and commissions you can support a family on? Must be willing to learn PPF and / or Vehicle Wraps if no experience. We are willing to train the right candidate. You bring the right attitude and work ethic, and we will train you for a very lucrative career. We’re offering a very competitive base salary against commission, with unlimited income potential including bonuses, spiffs, and incentives! Come join the fastest growing and highest paying auto styling company in the business. Why Join Us? Comfortable Environment: Climate-controlled installation facility. Precision Work: Use of a plotter for precision pattern cuts. Pioneer: The area's first one-stop shop for all automotive aftermarket needs. Franchise Support: All the resources necessary for your success. Growth: One location with more stores planned. Veteran-Owned: Focus on family and team. What We Offer: Competitive Salary against commissions. Full-Time: 5-day work week, 8 am - 6 pm, promoting a healthy work-life balance. Paid Time Off: Birthday, holidays, and vacation. Career Growth: Promotion from within and management training. Employee discount Year round work On-the-job training To submit a resume for consideration call or text Alex at (615)779-3132 or email alex.hellervik@tintworld.com Job Type: Full-time Pay: $40,000.00 - $100,000.00 per year Experience: Automotive Window Tint or Vinyl Wrap: 2 years (Required) Ability to Commute: Louisville, KY 40218 (Required) -
The direction of shrink
On some smaller pieces, sometimes. Mostly, no. The fingers will be too narrow to shrink down. If you do get it to lay flat the amount of stress you put on the film will shorten its lifespan. -
Hi all, First, I know little about tinting at all and am trying to learn how to do it as sort of a fun project, as I enjoy learning things like this. I was told that the film shrinks up or down, not sideways. If that is the case, would it make more sense to rotate the film and shrink perpendicular to the fingers, instead of parallel to the fingers? -
Graphtec Plotter
Graphtec Plotter
