New Prius C ????
Texastintchick
Guest Timbrook Tinting
For the new Prius C I have found out that if you remove them from the car it a whole lot easier . There is a 10 mm bolt that holds the track on and a Phillips head screw the holds it to the top under the wearer striping. After removing the track pull window out towards the back of the door. The rubber surrounding the window will come out as well. Remove the glass from the rubber. This technique will eliminate a light gap and no special hard cards needed. Before putting the glass back into the rubber be sure that the edges of the tint are sealed. I take my heat gun and warm the glass up around the edges to make sure the bond is good. I also do this on the back doors as well.
Guest k2mobiletint
If I took the windows out at the Toyota dealership, they would cry
    2. 2
    4. 8
    5. 8
    6. 2
    7. 8
    8. 8
    9. 8
