Graphtec FC7000 cutting problems
mikebrook_07
So I order a new cut strip and blade for my plotter and I'm having a hard time adjusting it to cut. In some spots it doesn't cut through the tint but on other spots it cuts all the way through the liner? Why is it doing this??? Most of the time when it gets to a corner it doesn't cut that out. Any ideas?
You didn't install the new cut strip correctly..... you need to be sure all the old tape and crud us out of the channel so the new cut strip sits perfectly flat... any rise or fall in the strip will cause the depth of cutting issue you refer to. :twocents
    2. 3
    3. 2
    4. 2
    5. 1
    6. 3
    7. 1
    8. 8
    9. 8
