seeking for autmotive tint installer ANGELTON TX
The above post is a bit controversial and naive in nature. May I suggest improving technical knowledge by using a film-to-glass chart, IWFA's study on window film use and dual pane glass systems, and glass itself. Air/gas used in dual and triple pane glass has zero impact on what gets installed. Absorption rate of film and glass edge quality impact the aforementioned glazing systems most. The film used in the OP has absolutely no business to installed to the exterior surface. Neither do the vast majority of film products that carry and absorption rate less than 50%. Start searching for good quality information to better serve yourself and your clients. And finally, installing on the exterior maybe has a life of 5-7 years before seeing degradation. Properly installing a product deigned for the interior on the inside increases life expectancy up 20-25 years, depending on the quality of the film. -
TintX Puremax and Koolmax
Did you install on the inside or outside? We always install the film on the outside (specially if it's double glass with air or gass between) If you install on inside it will be to much heat and crack is possible. good luck -
I see it's a lot of this films on alibaba.com but i'm sceptical to this. Btw I'm using Globalwindowfilms for daily tinting -
Hi tinter's + I'm looking for a good chameleon window tint film, anyone can recommend something? Mainly for installing on windshields, (innside ) Best regards Klaus -
Window tint full time position available
Car Tunes Llc 112 N. Parsons Ave. Brandon,Fl. 33510 813-661-4052 We are looking for full time window tinter 8-6 Tues thru sat ask for Shannan for details . -
Are you certain it's the film and not the actual windshield? You will not be able to "fix" a ripple in film. If you do remove it inspect the windshield carefully though. Could well be the glass has issues.
