2015 Ford transit rubbers
Hi All,
Has anyone got any advice on the new Transit windups. The rubbers seem to be one piece and SUPER  tight. Does anyone cut them?
Hi Darrenoid,
I would recommend posting these types of topics in the makes and models section under 'Ford' so you can get responses from across the globe, and not just Aussie land.
Me personally, I remove the rubber starting from the bottom front corner and pull it back to the top back corner. Then fold the rubber over the top of the door to get it out of the way.
I then tape up the front rubber that is still in the frame, just over the felt to prevent any felt coming from it.
You won't be able to put the window all the way up, but once you can slip the film down into the door frame, you won't need to. Then just slide the film forward into the front rubber until you go past the rubber 3-5mil.
Hard to explain without pics.
Hope this helps.
GTS, Thanks for the run down mate, very helpfull. The job wasn't that hard to do but I took the first door trim off and made it hard for myself. The next one went quickly. Again, thanks for the feedback, it's cool to reach out and get advice. Have a good w'end.
    Tint My Ride
      Is the 2022 palisade panoramic roof safe to tint
    6. 3
    7. 0
    8. 8
    9. 14
      South facing windows DR film
    10. 0
      The History of Window Tinting
