Santa Fe
Guest BTBP
Guest naughtydog
Did one today, pulled the panels as the panel scoops up at the front and does not allow you to get near the bottom of the glass. Remove a screw from the release handle under a cap, a couple of screws either side and it clips out like normal jap cars and then lifts up.
I did the full vehicle, the rear screen is a little tricky, lot of matrix. I sanded and it sat down sweet, I removed the struts to get a proper pattern, looked good but takes a little longer. Everything else is straightforward. I pulled the panels all round.
Naughtydog
    2. 3
    3. 2
    4. 2
    5. 1
    6. 3
    7. 1
    8. 8
    9. 8
