The crack indicates thermal stress, however, the edge of the glass may have has an imperfection (bur or clam shell chip). The crack does run 90 degrees out from the edge and curves as it follows any weaknesses in the pane itself. I have attached a pictured of what tempered glass looks like when it breaks and alongside it what a plate (or float) glass looks like when it breaks. The outer panel my be tempered usually indicated by a stamp etched on the glass surface in one corner. It should clearly indicate tempered. Plate glass has no indicators, however, heat-strengthened glass will crack in the same manner as plate glass. I'm an unsure whether heat-strengthened glass requires a stamp. Tempered glass is 4 times stronger than plate and heat-strengthened is 2 times stronger than plate. 1 in 24 is indicative of edge imperfection. I could not find the solar absorption rate of DN 50, but if it is similar to competitive films, there should be no issue with that installation setting (including a straight line shadow). This, too, points back to edge imperfection as the cause. And finally, I spy drapes in a close position, correct? If so, it would be helpful to crack open during sun exposure; this to assist in allowing trapped heat between the glass and drapes to dissipate. -
8
8
8
