AUTOMOTIVE WINDOW TINTER NEEDED ASAP
TintX Puremax and Koolmax
Did you install on the inside or outside? We always install the film on the outside (specially if it's double glass with air or gass between) If you install on inside it will be to much heat and crack is possible. good luck -
I see it's a lot of this films on alibaba.com but i'm sceptical to this. Btw I'm using Globalwindowfilms for daily tinting -
Hi tinter's + I'm looking for a good chameleon window tint film, anyone can recommend something? Mainly for installing on windshields, (innside ) Best regards Klaus -
Window tint full time position available
Car Tunes Llc 112 N. Parsons Ave. Brandon,Fl. 33510 813-661-4052 We are looking for full time window tinter 8-6 Tues thru sat ask for Shannan for details . -
Are you certain it's the film and not the actual windshield? You will not be able to "fix" a ripple in film. If you do remove it inspect the windshield carefully though. Could well be the glass has issues. -
4,169
