My first graphic job
Guest naughtydog
Guest naughtydog
I have a friend that has a new mini cooper and he wants a graphic installing on the roof.
Now I stick film but I have never done any graphics?? Can you mount them wet like film ? and what mounting solution should I be using.
Appreciate any help
Naughtydog
Guest nautiboi73
I use a rubbing alcohol soultion. I have used mymounting solution but it takes longer to set for me. The alcohol soultion will still give you time to set it but not take as long. and I always do mine with tranfer tape. If you are going to use a blade on teh car then maybe you might want to use same mountinng solution.
.02
