Oh crap
tint45
I decided to yank the panels on this and I unplugged the window harnesses, now after plugged back in the windows don't operate. :poke I've seen something on here before about how to correct this but I can't find it. Please help. thanks :thumb
:? Nothing from me but check the fuses, did you turn the key off before plugging back in? If not turn key off unplug and plug back in. Did you cheat the door lock for the window to go up? reset it?
Thanks micro. False alarm. I did the passenger side first. Once I plugged the master switch back in on driver side, all was back to normal. :poke Also, I couldn't trick the windows up on these, found that to be the same on an 07 Benz convertable. :thumb:nono
