Just a little heads up!
Guest Tinted
Guest Tinted
Allright, if you get a small crease or slight contam heat it and bone tool or popsicle stick it out! 10 seconds max. Be careful too much heat will screw you up and you'll have to re-do.
Guest mastertinter
I love that tintinator..." I am going to plan to go in monday morning and throw a big fat crease in my tint" just so I can try and heat it out...
Just sounded funny man... I find if you do get a small crease during shrinking you can also work it out before you install the film by lifting the film off the glass and pushing the crease down with the chisler while lifting up on the corner of the film, this helps to iron out the crease. Then she heats right on down once installed.
the best way is to take your time and avoid creases all together.
    2. 3
    3. 5
    6. 3
    7. 3
    8. 3
    9. 4
    10. 0
