Colorado door windows
Guest clear image
Guest clear image
If you tuck the film below the door felt on a Colorado you have to tuck it about an inch below or more. There is a secondary felt strip below the visible door felt molding inside the door. If you tuck the film below that gasket the film tends to finger up. To eliminate that problem, before you cut you film, roll the glass down. Take an extended olfa blade and just cut that inner felt gasket all the way off. Then install. Cake after that.
Guest God_Of_All_Tinters
Just don't bury it as deep as you normally would. 1/4" below the topmost gasket should be sufficient. No reason to try and shove it down to the rocker panel. :spit
