05 Impala and 04 Cavi coming this week
Guest NDBuckeye
door skins easily peel back on both (remove the gaskets on the impala , If using a metalized film on the impala , warn customer of AM interference, have a solution ready for the dot matrix on the Cavalier (elmers glue or black vinyl) If the Cav is a 4 dr, be prepared to do a bit of shrinking on the 2 back doors (only slight shrink or stretch if it's a 2 dr :passout
on the impala,(just did one yesterday), take out door handle area screw, and on fronts, top screw, roll back door panel top edge, it will pop back, pull out rubbers, when you put the rubbers back in, make sure you pop the door panel top edge back over the clips along the rubber, or it will stick out a little bit. cavelier?, I'm pretty sure I take those panels off, felt beasts
