Scratches on glass
Guest uniqueimage
Guest uniqueimage
Ok, one of my employees scratched a customers glass when cutting the film. Is there a way to get this fixed without buying a new glass? There are lines on the outside of the glass. It was a brand new altima so I don't think they were there before.
The rule of thumb (others here can verify if I'm wrong or not) If you can't feel the scratch with your fingernail, you may be able to buff it out with a creme that jewlery stores carry with elbow grease .
If you CAN feel the scratch with your fingernail..your buying a new pane of glass
Guest uniqueimage
My shop at one point only did mobile electronics. I expanded about two years ago but man its hard as hell to find a good tinter and keep him. So I had to step up to the plate and learn it. What else could I do??? I have a part-timer coming and doing work. How did he do that anyway? I've never experienced that.
[*]334712
Where do I start .. :rollin
Not using stainless steel blades
Not "snapping his blade enough whe nit dulls
Not holding knife at proper angle
Pushing too hard
There IS a bit of a knack to cutting out patterns..it's a "feel" thing which only experience can ge you through all the degrees of softness of different glass..not all gladd is the same :thumb
[*]334690
[*]334712
Where do I start .. :please
Pushing too hard
There IS a bit of a knack to cutting out patterns..it's a "feel" thing which only experience can ge you through all the degrees of softness of different glass..not all gladd is the same :lol6
[*]334713
:evileye
Guest Sprinter
I start out with a fresh blade and the rear window in 10- years I think I've only scratched the rear glass 3 times, I remember cleaning off the outside of one to discover cut marks already on the glass with out any film on the car perfect pattern all the way around, turned that one into mr customer before proceeding.
Guest Beeline
:gasp:music:whisper
[*]334690
[*]334712
Where do I start .. :hmmm
Pushing too hard
There IS a bit of a knack to cutting out patterns..it's a "feel" thing which only experience can ge you through all the degrees of softness of different glass..not all gladd is the same :gasp
[*]334713
:gasp
[*]334845
    2. 2
    4. 8
    5. 8
    6. 2
    7. 8
    8. 8
    9. 8
